Old 05-23-2013, 10:22 AM   #27 (permalink)
E300D
I know this is old.But...
Couldn't you just use construction adhesive around the entire perimeter?
Or use epoxy resin? Obviously you would scuff the bejeezus out of both surfaces using the roughest sandpaper available
I suggest:
cut out the center of the hubcap,
scuff both surfaces really really well and drill several holes in the cap to let the adhesive ooze through.
then lay a thick bead of construction adhesive (press together remove for two minutes and then replace)
Let it dry really well. Apply another bead of adhesive
Has anyone tried this?
