Old 05-23-2013, 11:43 AM   #40 (permalink)
oil pan 4
I don't deal with these things much—if the turbo muffles the exhaust, would it do it with more or less restriction than a passive muffler with equivalent effect? Could you 'tune' the turbo for maximum acoustical results?
I run a straight pipe on my turbos.
If you use a Holset, they are very quiet. When I was only running the Holset with the straight pipe it was quieter than when the engine was N/A with factory mufflers and full exhaust.
The Garretts are a little noisy.
From back pressure tests others have done with Holset HE351VE and HX40 turbos with a straight pipe during normal driving the back pressures are about the same as the back pressure I got when I had the factory mufflers on there.
freebeard (05-23-2013)
