15w or 10w or 5w or 0w....is flexible depending on climate...the ending part not so much for me. I absolutely wouldn't suggest any lighter than an HD 5w30 or 0w30 oil made for diesels like Rotella. With the huge compression diesels low lubricity diesel fuels produced today, the lowest I would go is 40wt. (ie 0w40, 5w40, 15w40). There is little to no fuel gain to be had running any lighter and lots of engine wear at risk.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
