Old 05-24-2013, 05:42 AM   #8 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by RobertISaar View Post
you realize that when the oil is up to full temp the 0/5/10/15/20W rating is of no importance, right? that specification is for when the oil is cold, the second half of the rating is viscosity at 212*F.
Not according to bobistheoilguy.com
For 2013 Cummins is saying that 5W30 is ok in heavy duty truck engines. I think they are coming factory filled with 10W40 instead of the usual 15W40. However, talk to anyone at a Cummins dealer and they will tell you that 5W30 is wonderful until you find your engine worn out in 2/3 the time as normal.
The Following User Says Thank You to mechman600 For This Useful Post:
mikeyjd (05-24-2013)
