For what it is worth, I am starting to suspect that mine was more a grounding issue than a bad battery. The old battery looks okay. I imagine I did a better job of grounding it when I attached the new battery. No matter, I have another car that needs a battery. I will just switch the terminals. Still, what I said about batteries holds true, and I got a good lesson on proper grounding as well.
