All the stuff came from home depot or a cheaper equivalent part from ebay:
3/8" bolt through square washer, screwed into those unistrut spring things:
Push into unistrut channel, then rotate clockwise 90 degrees. It won't let you rotate it counterclockwise:
Torque that sucker down! The panels can take it!:
