Another topic ... that is a BIT of a tangent, but not REALLY
I am planning to use the Electric Motor Module in my side by side WIKISPEED Quad.
But the motor should still run in the range 2000 - 3500 rpm, so that it cools properly ... so second or third gear is not really appropriate.
First gear! 14.75:1 gear reduction. 3500 rpm input to the transaxle will generate 237 rpm output.
From EV calc, these tires (which are likely larger than quad tires) give 902 rev/mile = 5.8 feet or 70 inches or 178.4 cm per rev. 237 rpm gives a distance of 42285 cm per minute. 422.8 meters. * 60 minutes is 25.37 km per hour or just under 16 mph. That's good enough. And I can recycle the tires that I was going to use on my SalvageS10 project (that's on the shelf
Using the redline of 5500 rpm, you get 40 km per hour or 25 mph. That's good enough for a side by side quad!
And dropping down to 2000 rpm, not as a minimum but as a minimum for cruising ... gives 14 kph or just under 10 mph. Faster than walking, but not running.
It will have PLENTY of torque on the low end with a DC motor and 14.75 to 1 gearing. The plan is to use a second motor and transmission at the front of the vehicle, to give part time 4 wd. The controller on the front unit will have a second output contactor, to connect to 'power take-off' or PTO. Come to think of it, the same is true for the rear unit as well. The DC or AC motor will be part of the appliance to be driven - roto-tiller, snowblower, hydraulic pump (which has many uses) ... perhaps even a three-point hitch! I've ALWAYS wanted to have a 3 point hitch!
