Old 05-25-2013, 11:41 PM   #6 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Yes, monitoring each battery voltage under load while you drive very quickly sorts out which batteries are toast. I think I bought six volt meters on eBay for $24. You can wire them to your pack with only 7 wires (instead of 12 like you would assume).
This is what I use:
Plugged into the car with this connector:
[IMG]http://i1119.photobucket.com/albums/k634/mechman600/54e56760.jpg[/IMG}
The Following User Says Thank You to mechman600 For This Useful Post:
RobW (05-28-2013)
