Old 05-26-2013, 10:32 AM   #6 (permalink)
kach22i
Xist, thank you for taking the time to compile these collections of posts.
Originally Posted by ChazInMT View Post
The Aero template is a tool, designed to be used a certain way for best results. It is meant to overlay on a car with the high point on the top of the car at its highest point, and the bottom chord at the bottom of the tires.
I have to slightly disagree ChazInMT, the template is for an idealized 3D shape, and the way it's often used/abused in the forum is in 2D profile only with little consideration for the resulting vortexes. And when used, it is affecting only the upper aft canopy above the tires or pick-up truck bed.
I've explored this issue from several angles in an attempt to gain a better understanding, going from a 2-part body to a 5-part body. See thread linked to below.
http://ecomodder.com/forum/showthrea...tml#post292262
The very idea of adding mass/frontal area to a vehicle such as the type above to meet an idealized template requirement which is not specific to this vehicle's task runs counter to common sense to say the least. And begs the question: then why try it to a common road vehicle?
If there is another way to enclose the wheels of this car without adding mass (area), I'm open to suggestion.
As mentioned in the 2012 Mustang verses the 1978 Escort thread, the frontal area is as important as anything else affecting the drag.
Auto Union Type C Streamline
http://www.motorabilia.biz/models_(1).htm
With a drag coefficient (cd) of just 0.24 it is better then the Mercedes Benz Streamliner with a cd of 0.25.
