Originally Posted by ChazInMT
The bottom of the boat tail should not exceed 10° from what I've seen in ecomodder a bunch of times, so your template under the template thing isn't really a good idea.
When I posted my pictures, Aerohead wrote:
Originally Posted by aerohead
I'd maintain the upper curvature as you have it,but for the lower,it will depend on where you begin your diffuser.So it's angle will be 2.5-degrees,or around 4-degrees depending,and you can ignore the red line since you have so much ground clearance to begin with.
You may want to do it in 'installments',to see how you like parking 'n such.If you think you can live with more length then go for it.
I did not try to figure out what that meant since I only shared the images for entertainment. I guess that I was the only one that thought that it was funny.
I usually am.
