Nice, guys! Someone mentioned a "throttle joint". It's also called a "heim joint" or "rod end". I wanted to use one of those but couldn't find one. You'd think Ace Hardware would sell them.
Originally Posted by sendler
How will the bike lean with the wooden trailer on?
It will lean the same as any other one leans. I'm re-using the kiddie trailer's hitch, which just has a section of bendy rubber. It's not as sophisticated as my copper trailer's hitch, but it's cheaper and it works.
EDIT I think I see what you mean. The U shaped metal piece is just part of the kiddie trailer's hitch arm. It's designed so you can put a third wheel on it and push it while jogging. Obviously I'm not going to be doing much of that.
Darin, please post pics when you get that catamaran behind a bike! I would love to see that.
