Just got my MPGuino, still have to install it. Once I get it all set up I will be doing some A-B-A testing to figure out exactly what this grill block is getting me
This will be the first time I will actually be able to do any testing, I'm excited. I will be testing on a section of flat road with my cruise control set to 60mph and will not turn the car off between tests, so that I can use the resume function for better accuracy. I will also be sure to do record temperature and wind speed, along with direction at the time of testing. I will also be sure to perform all tests traveling in the same direction each time.
The test will be:
A - 60mph - grill block propped open.
B - 60mph - grill block able to close on it's own.
Am I missing anything?
