Finally got the TDI motor in the truck.
Pulled the old gas tank out and had it cleaned
When pulling the filler neck out, I tried disconnecting this and ended up breaking the plastic off in the dry rotted hose. What is this for?
I also picked up a diesel rabbit filler neck as I didnt want to deal with modding the gas on to work. (I will post up a side by side to show the difference soon)
Now on to the fun stuff... everything else.
Wiring
Hydraulic shifter
Fuel tank install
Brake booster?
Clutch master?
Intercooler piping
Radiator
