Thanks for the tips.
It did not buzz initially, it only started just before it came off completely.
It already had the stalk at roughly 30% btw and its internal structure made it quite rigid; the trailing edge was a glued double layer. But I will use a solid wing in the final version.
Maybe I'll give it a slight shark fin shape, expanding the (bulky) base forward. Cant do much on the back of that as the spray nozzle sits there and the hatch needs to open fully.
