Originally Posted by mora
Raw code is readily available in ecomodder wiki. If you happen to know how to get it compile correctly, please let me know. I'm struggling with it. Hehehe. I know it is some user errors.
Open ReVolt/Software - EcoModder
The code for the controller needs to be compiled in linux. It WILL NOT compile inside AVR studio.
To compile in linux, Install avr tools and development tools. Then copy over the source files and navigate to the folder. Do a make or make all I believe and your all set.
If I get a change, I will put together a video and a VM ware player image with everything needed.
-Adam
