Old 05-29-2013, 09:02 AM   #6132 (permalink)
mora
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
No wonder it didn't work for me. Hehehe. VMware will be good for this.
I read from readme.pdf found inside code archive 1.11b, that c-rr parameter is amps per millisecond. If default value is 6 doesn't this mean there will be 6000 amps per second? That's a pretty fast rise time, let alone if you set value to 20. Even value 1 will result in 1000 amps per second. Could this be modified to something like amps per 10 or even 100 millisecond? Maybe for next code release. Or is there a specific reason why it is so steep?
The Following User Says Thank You to mora For This Useful Post:
MPaulHolmes (05-29-2013)
