Thread: EP3er Here
Old 06-22-2008, 11:37 PM   #3 (permalink)
greenwar
FWD - '04 Honda Civic Si
90 day: 34.09 mpg (US)
RWD - '04 Honda S2000 NA
90 day: 27.25 mpg (US)
Welcome to the forum
Hi there,
Welcome to the forum. I drive an EP3 as well. I try mild hypermiling techniques and get around 30-35 mpg in mixed city/hwy driving. I mostly do city driving though. My commute to work is very short so engine doesn't really get to operating temp until the end of the commute to work.
You mentioned you put in 46psi in your tires. Does that make the car bumpy? My ep3 is extremely bumpy even with 34psi in the tires. I wonder if the previous owner replaced the springs on my car. I replaced the front struts that make it livable.
The tires I have on my car are 205/55/16 Bridgestone potenzas that are grippy hence bad for achieving good gas mileage. A touring tire would have been a better investment for me. I am thinking about trying 15" tires on my car which should help with the ride. I wonder if they put larger brakes on the 04+ ep3s which seems to come with the 16" wheels.
Good luck achieving good FE. Consider getting a scangauge II if you can. Ecomodders get a discount when buying that gauge.
Regards,
Greenwar.
