Not sure how to factor that in. Most of this spreadsheet was from another person who made his own ebike and I have made a few changes and additions to it. He did not opt to use lithium, so the math on that may be off, I just dont know what I would need to change.
Is my formula for MPGe correct?
(Driving Range x Gas kWh) ÷ (Voltage x Amp-Hrs/1000) = MPGe
My math:
74.59miles x 33.7kWh ÷ 7.04kWh = 357 MPGe
This also shows that if my driving range is lowered (say due to the ~80% Depth of Discharge) my MPGe will also be reduced.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
