VERY glad to see that my goals seem reasonable. You had me down for a bit with the 400 Wh/m thing. I thought I was going have to be swapping the ebike idea for just building a recumbant reverse trike (pedal power). I realize that this is all theoretical for now and the actual results will definitely vary, but I am just making my shopping list and crunching the numbers right now.
Thanks for the help. If all of the numbers seem to be ok now (thanks again for the edit) I guess all that is left is to build this thing (when funds permit).
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
