Old 05-29-2013, 05:38 PM   #1 (permalink)
DJeXeCute
The Purple Prius Eater - '98 Dodge Ram 1500 Laramie
90 day: 15.07 mpg (US)
V8 Ram Saving Gas
I have a 1998 Dodge ram 1500 rwd 5.2L 318 V8 Stroked to 402cui, poly heads, ported valves, aluminum intake, larger throttle body, long tube headers with highflow cats 3 1/2" pipes with dual 3 chamber mufflers to keep is livable sound wise(I forget what kind they are), Ecu is reprogrammed to shift at lower rpms and to lock into gear from 1000 to 1200 rpm for the most part, Axle is a Dana 60 with 3.23 gears and a detroit locker for better traction on and offroad. I average about 17-18mpg the way it's all set up which is allot better than most other rams like mine get but I'm still looking for a way to get better city mileage. The trans refuses to stay in gear while going up hills even though its got more than enough power to idle up them so I think I might try another shop and see if I can have them set it up to stay locked. My other mechanic says it's not possible to completely disable that but we'll see. Oh did I mention 47k Original Miles, it's been in the family since new and only driven by my late grandfather and me this past year.
What do you guys think I could do from here to get more out of it? I'm thinking custom fabbing a Tonneau cover for the bed since I have a diamond plate toolbox and bed rails and want to keep it all intact. Other then that I think I'm at the end of the line as far as gas mileage gains.
