One inch on a Prius is like having 4 adults in the car so I wouldn't stress too much about it. I would go with the TRD springs as they tend to be the best spring rate balance daily driver/performance as Toyota can back their install with warranty and will most likely have the least impact on the life of the strut shock absorber after stock.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
