Originally Posted by kach22i
*From the side,the 'Template' is half of a teardrop,minus what is cut away to create the ground clearance.
*When the Template is coming at you,you see a semicircle minus the area removed for its 'ground clearance.
*From above you see a full teardrop.minus the area which was cut away for the ground clearance.
The intent of the 'Template' is to provide a safe contour for boat-tailing primarily passenger cars,as they are the majority of vehicles sold.
*based on whatever your starting with,however you can morph it,and integrate it into your vehicle,it would provide a separation-free surface for reducing pressure drag.
As to the overlay,well the problem is that it is perfect.It is the tyranny of singularity.Some people will never lose their attachment to the notion that you'd never find a single solution for drag reduction.
I have some additions I'd like to add to the thread.I've been without transportation for going on 12-weeks now.I hitch a ride into town to come here.When I leave I have a 7-mile walk home.It's a bit awkward to carry materials here and back.
I have every intention to 'complete' the thread.I have no earthly idea when I'll be able to do that.
If you want to depart from science go ahead.You're certainly under no obligation to anyone.Perhaps you'll find solutions elsewhere.
Best to you!
