Old 05-30-2013, 10:52 PM   #385 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
MK1, 2, and 3 VW's all share rear suspension styles. It's a beam that runs close to the body, some have a sway bar inside the beam, but each has a trailing arm 'leg' that the hub bearing assembly bolts to.
Festiva, Aspire also have them. They're all a total of 6 body bolts, shocks mount inboard of the wheel almost at the centerline of the bearing.
The Following User Says Thank You to Christ For This Useful Post:
NeilBlanchard (05-31-2013)
