Originally Posted by California98Civic
I suspect it will swap without issue because so many of the elements are made swapable on the 1992-2000 transmissions.
Thank you for the quick and detailed response. I have tried using hona-tech.com but I have completely given up on that site because every time I post anything on there I recieve nothing, but smart*sses and haters, I prefer d-series.org now, but all of them seem to think that swapping for a taller 5th and final drive will not increase FE at all, so it just lead to arguments. I have tried to explain it to them, but they don't listen. That's why I am posting here.
There should be no trouble with the linkage: they're both hydro, correct?
Yes they are both hydro.
Wheel/tire size alone will change speedo readings relative to what you are used to, though in general the Civics appear to overestimate speed and underestimate distance by factory design.
This did not make since to me... Could you reword or explain further?
