Old 05-31-2013, 05:01 PM   #102 (permalink)
tony_2018
Well you have the struts replaced, but safety wise, what about your braking. If ever in need of emergency braking how will your stock setup handle the extra weight coming from back? Also when swirving out of the way of unseen objects on the road? Things to think about and I'm not hating on this add-on. I'm actually digging it as i also drive a 99-00 civic sedan.
Lighting on the road I've done HID retrofit, suspension wise I now have koni's with stock suspension so the ride is stiffer and adjustable if need be, I'm looking to lowering the car a bit and looking at stock options of either the sporty civic type r springs or the sporty integra type r springs. For swirving out the face of danger I'm looking into upgrading my swaybar to a more stock oem integra type r and a rear civic si swaybar. I've also consider lighter rims, civic HX rims, or using the moon hub cap rims. I'm totally happy with the gas mileage I'm getting a combination of citiy and highway I get 30mpg and straigh highway I get 40mpg, if I'm in lean burn mode I get a +.
