Originally Posted by tony_2018
Can you explain what you mean by using a resister per car? This looks interesting to me as I have an automatic.
Knowing what the resistance value of yer TC solenoid is will determine what the proper resistance value you need to substitute in the diagram. Fer my transmission...the value is ~13ohms so I would use a 13ohm resistor. I'm pretty sure that all TC solenoids are not the same value.
