Old 06-01-2013, 02:40 AM   #322 (permalink)
some_other_dave
Originally Posted by RatherDashing View Post
I did that. the timing is right on. does it matter if the timing marks while checking the timing without the jumper wire on aren't aligned constantly?
Not a problem, it just means the engine management system is modifying the timing. You jumper the connector to tell it not to change the timing while you're checking.
no vacuum and really hot when just the ignition on. quite weird, replace? or clean? or is that normal?
Sorry, I can't tell what that part is.
-soD
