Quick Question on MPGuino Install
Got my MPGuino a few days ago and finally have the time to install it tomorrow. Everything from what I have read seems pretty straight forward. Attach power (always on), good ground, vehicle speed sensor and injector. What confuses me is that what I read says to unplug all of the injector connectors and use the one with NO voltage. Does that mean use a negative wire or does that mean that 1 of my 4 injectors will literally show no voltage when I put the key into the "run" position?
Sorry for the stupid question, but I would just rather have everything figured out before I start running wires and pulling my dash apart.
Thanks,
Andrew
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
