Old 06-01-2013, 03:48 PM   #560 (permalink)
aerohead
Testing
Wind tunnel testing for the 'Template' was originally conducted by Wolfgang Klemperer in 1921 at the Zeppelin Werkes.
It's been re-tested by various aerodynamicists throughout the decades since,including Hucho.
This 'original' 'Template' is the Jaray half-body,derived from an airship hull.
Hucho uses Jaray's roof contour as a benchmark for boundary layer integrity and separation-free,attached laminar flow.
Roof contours steeper than Jaray's roofline are what Hucho refers to as 'pseudo-jaray'.These roof contours produce separation and very strong attached longitudinal vortices of remarkably high drag.
The 2.5:1 'teardrop' from which the AST-I&II are derived are well-tested and produce Cd 0.04.
The 5:1(effective fineness ration) half-body derived from the teardrop is well-tested and produces a body of Cd 0.08 in ground proximity.
When wheels.tires are added to the half-body,the drag increases to Cd 0.12-13,depending on tire width.This has been well-tested.
When wheel fairings are employed,the drag can fall well below Cd 0.12.This is well-tested.
In light of the fact that so much testing and re-verification testing has been accomplished since 1921,it's extremely unlikely that the aerodynamicists involved have missed anything significant.And so,the 'Template' could pass for off-the-shelf technology,nothing theoretical about it anymore.Just waiting to be exploited.
Any members with Hucho's book(s) will already know that he'll tell you that there a plenty of ways to get to Cd 0.15.If you want to go any lower,then you must extend the back of the body,while reducing its cross-sectional area such as not to produce separation.And Jaray's profile guarantees success here.
Of course,no production car is circular in cross-section.They don't need to be.As long as any elongation of the body produces only the progressive reduction in cross-sectional area as with the 'Template' there shouldn't be any separation,nor vorticity of any significance.It's structurally impossible.Sectional density is respected to the highest degree.
And so it's my humble opinion,that we've had enough testing.We've tested the thing to death.And it always delivers the lowest drag (for a car you can walk up to,open a door,and get in or out of,without a bunch of teammates to help).
jime57 (06-02-2013)
