Originally Posted by jackbauer
Re-moc is alive! Video uploading .........
...where is this video , please? ( I have checked your youtub profile but is not there)
After my second set of mosfet failed, I have decided to put more of them in TO220 case
- I want to change IRFP4668PbF for irfb4115gpbf (150V 11mohm 70A ) 22 pieces
1. I want to ask is mic4451YN can manage those 22 mosfets? And do I need to change resistors gate parametrs ?
Data S:
mic4451YN
http://www.micrel.com/_PDF/mic4451.pdf
MOSFET Ciss Input Capacitance ––– 5270 ––– pF x22=115940 pF
mic load drive is 62000 Pf looks it is not good
or I need to check just Gate-to-Source Forward Leakage it is 100nA and mic can work on 2A - I am not so sure is this is OK.
2. What about resistors, have they need to be amended?
3. Another important question I aware my fail could happened becouse of spikes from motor could produce over voltage - can I protect my controler with some kind diode or transil installed on motor? (Motor parametrs 80V 200A 13.5 KW DCseries)
For any help thank you in advance.
