Old 06-02-2013, 10:06 PM   #44 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Mazda
Part of the Skyactiv D's innovative technology is variable valve lift of the exhaust valve during the intake stroke. This enable hot exhaust gas to heat the cylinder to improve combustion stability during warm up. The lift is changed by this hydraulic device on the cam follower which engages a rubbing pad on the center part of the unusually shaped exhaust lobe of the camshaft.
