Old 06-02-2013, 11:17 PM   #62 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Not up on the Insight ...
Originally Posted by rmay635703 View Post
too bad the chassis wouldn't easily fit a Honda Insight G1 setup, that should push the FE a tad past the 109mpg
Cheers
Ryan
I apologize - I'm not up on the Insight G1 specs .. but google shows that they are pretty darned impressive.
The WIKISPEED SGT01 can do over 100 mpg using a stock Honda R18a engine. It was built to do over 100 mpg, because that's what the X-prize specified. After that, it was a race, so the design did not use the most fuel efficient engine. It's still got very good performance. I'm sure that the G1 powertrain in a car that light aerodynamic would be very impressive.
The car IS modular, so if someone were to locate an Insight G1 motor/transmission/axle set that needed a new home ... it could be built into a module and swapped in for a test. Not sure if it would all fit into 40 x 40 x 20 inches, but it would be fun to try!
