Originally Posted by ChazInMT
........ it was created with the use of the line.
But a line has no scale if it's not anchored to a particular body platform, making my case for re-scaling the template even stronger (the catch-22).
I should troll this thread with Dymaxion pictures. That pointy tail always bothers me. Seems fragile.
If you think the tail is frail, try sitting in the front when conventional car makes a hit and run on you.
Untitled Document
EDIT:
Template away, I found your car.
http://forum.donanimhaber.com/m_31437284/tm.htm
