Originally Posted by knochenhauer
At what temperature does a typical thermostat open fully?
Each thermostat is different. Typically thermostats are specified by their crack open temp, i.e. a "190 deg stat" starts to open at 190 deg F. For most stats I've seen, full-open temp is ~20 deg F above the crack open temp.
