Old 06-03-2013, 10:23 PM   #178 (permalink)
jime57
OurInsight - '06 Honda Insight
It would probably "advance the art" to have before and after testing on the undertray. From what I've read, I think the undertray is important to the performance of the boat tail. In fact, I think I remember that you found that the case with the Metro tail.
As you know, I don't have much faith in fine grain measurements on the Insight because of lean burn, but I am pretty sure that a full undertray has improved the fuel economy of my experimental unit. I just can't provide a number. Hucho and most of the cutting edge manufacturers, including Honda, seem to think it helps.
If your stock under panels are intact, then you need a fairly small piece of coroplast to complete a full under tray. Because the shape is rather complex, I'd start with a piece of cardboard as template. It is a single plane of about 3-4 degree uptick from the little plastic deflector at front of axel to the bumper cover. Attachments are kinda scarce.
The Following User Says Thank You to jime57 For This Useful Post:
MetroMPG (06-04-2013)
