Hi Superturnier
What you have described with the vacuum sensor (GM map) is sitting on my bench ,although the problem with this system it does not take into account power valve enrichment or Secondary barrels + enrichment if so fitted & as you mention the choke,so who knows what the outcome will be?
What we are tallking about here is not the end product, this is just part of the development process,which has the potential to be a stinker at the end.
I have used Zemco's since the mid 80"s & as you note that ball sensor was just unreliable ,Have also tried other sensors too ,but most of these not linear & at low flows simply do not measure anything,which also causes problems with accuracy.
