Old 06-04-2013, 12:15 AM   #8 (permalink)
hat_man
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
Told you all I didn't know anything. LMAO. So I guess that's an intake then. If that's the case then if you leave the grille open and the area in front of the windshield is an intake also, then all the air must leave the engine bay from the bottom?
In my un-aero mind then I still have a question. The article says that you need a pressure differential across the radiator to create flow to move air through the radiator. If the area in front of the windshield is an intake, as is the grille area with it's big gaping hole, then would there be more radiator cooling if you closed the area in front of the windshield? Just to use some arbitrary numbers if the grille area has +10 units of pressure and the area in front of the windshield has -3 units of pressure (because it's on the other side of the radiator), this makes 7 units of pressure across the radiator. If you close the area in front of the windshield (making 0 units of pressure) this would make 10 units of pressure across the radiator, right? This is assuming the "exit" air flow is out the bottom of the engine bay. All the other areas are intakes.
And secondly, if all this is true, if you put a belly pan under the engine bay and the grill and windshield area are intakes, where and how does all that air leave the engine bay?
I'm sure there is a logical answer, but I just can't wrap my head around the concept.
