Old 06-23-2008, 11:17 AM   #7 (permalink)
Smog
Tacoma - '06 Toyota Tacoma 2wd access-cab base trim
90 day: 32.03 mpg (US)
Originally Posted by ebacherville View Post
1 minor downfall, it tends to concave, you'll have to make a nice framework to get this right on for areo.. but if its a quick and dirty thing yeah it should help...
However a clear would be pretty cool.. just paint what you want to not be windows.
I was giving this idea, may be it's not the best but it's a cheap option;
another cheap Idea to cleanly block foglight recess : get your local vinyl signs shop cut you a set of sticker a half inch larger than the opening in the bumper. Get a piece of coroplast (the sign guy must have some leftovers), cut it a bit smaller than the fog opening. put the coroplast piece centered on the sticky side of your vinyl cut then put it on your bumper. the coroplast will keep the vinyl patch straight while the patch will deflect the air away and be almost invisible.
