Originally Posted by AndrzejM
MPGuino works constantly that's why it's connected to constant 12V.
And if you want to have another position in menu with temp reading you just need to create another menu entry and then add proper code for that entry.
Okay. Thanks. Still figure it out for the menu.
By the way, can i use the 16x2 LCD without I2C interface for the LCD? I mean, can i just upload the 0.82 to my MPGuino? Mine using the Freeduino schematic (without I2C interface). Cause i saw you use the 0.82 version. But, i'm still unsure for the LCD you use. I'm using 0.81, everytime i'm starting the car, it always start with a zero. It doesnt save the last trip value to the EEPROM.
Tomorrow will be a holiday in here. I'm planning to put the +12V directly to the battery. After that, i want to move the LCD and the switch to the dashboard. Then, it will the time to calibrate the injector. The VSS is running well (with the 5100 for honda civic 96), although at the >100 KM/h, MPGuino showing 3-4 KM slower than my speedometer.
Thanks
