Old 06-05-2013, 02:33 PM   #584 (permalink)
kach22i
Originally Posted by ChazInMT View Post
the template..........
It never changes its proportions, only its size.
I agree!
My overlaying on the various foils above was meant to show you what you're talking about doing when you rescale the template.
No, rescaling means exactly that, and as you yourself stated "the proportions stay the same". What you did was just plain silly and an attempt to confuse the issue, another strawman argument of yours.
Where do you get the idea I altered the template.
Maybe it's because this thread is such a mess, but the only "line template" of the arc you are using is in your own photo account. The attempt to shorten the template is a response by the template worshipers to make it relevant when it hardly is.
FYI back at cha... Foils are wings, they're 3d, we're just looking at a cross section of it.
Bingo, half way there. Now if you can only see a wing as I do (see below) and acknowledge that arc is representative of a section cut, you might understand why the 3D shape and its side curves or terminations are so important. This is the drag you should be concerned with. Oh, and wings come in different sizes (LxWxH) yet may use the same NCAC profile (ratio), getting it yet?
Turbulence Modeling | CD-adapco
Maybe you should look at it in more than section, try plan view or perspective once in a while. Wings don't go on forever, they have edges - and messy ones too
Are you going to question the base line optimum shape too? Do you have a better shape that, "Looks good to you"?
I like the template arc for what it is, a starting point, and one I still use. It is however nothing more than a reference, it is not even a design.
And finally, the illustrations you put up are drawings of what people think the air is doing over the surface of the car. They're drawings.
By people you mean "me" when I draw things? Then yes, but everything I've drawn is also supported.
The CFD illustrations are a pretty good guide, I really don't think people are manipulating them by what they choose to think. They are only choosing which points to tag and follow.
Okay enough wasted time, took my lunch break, now back to work y'all.
