Two different threads that are the same is making my head hurt.
So now there's one. Daox dropped the hammer.
Filleting works on the inside corner edges, not so much on the outside corners.
kach22i -- Off-topic, but here's the only house I ever designed that was built.
Aerodynamic on the outside and inside. You could ventilate most of it by opening a door on the 2nd floor deck and the 'joe-sent-me' peep-hole in the entry door. Air would flow over a wall under the skylight.
