Old 06-06-2013, 10:26 PM   #66 (permalink)
kach22i
One of the members shared the NUNA solar car with us.It's makers claim Cd 0.07,a remarkable acheivement! That car has every component fully boat-tailed either in plan or elevation.You can argue over it's practicality as a daily driver,crashworthiness,etc.
It does not fit the template, but the canopy does if scaled down.
http://s184.photobucket.com/user/kac...?sort=3&page=1
Maybe it's one of those outside the template wonders - lots of them.
I just found a good paper talking about some of Jaray and Klemperer's work. If you take a foil and place next to the ground the drag can increase 50% to 500%. However, if you remove the lower camber making it a flat bottom foil you can greatly reduce that drag. You can also arch the top side of the body more to similar affect!
See page 13, rest of the thesis is pretty good too.
http://epubl.ltu.se/1402-1617/2007/0...X-07007-SE.pdf
aerohead (06-08-2013)
