Old 06-06-2013, 11:08 PM   #40 (permalink)
XYZ
I did essentially the same on my car, but found that it ran too hot in summer. After all the meticulous work of designing it, I had to remove the permanent lower grille block I fabricated. My aluminum upper grille block is surface mounted and easily removable during warm weather, so that's no problem. The partial belly pan in front works well and is easily removable if I ever need to service that area.
Nice job. Hope yours doesn't run too hot.
