well. brand new transmission is leaking fluid I believe. right around the axle seal. taking it back to the shop that put it in. I believe I still have an extra. had them put 10w-30 oil in it as well he almost put gear oil in it.
when its outa the shop whats best for it since it does only have 6k miles on it. 10w-30 oil regular, synthetic, or the Honda mtf, I seriously keep seeing different responses everywhere. that the older trannies were meant for regular oil and that the newer ones can handle Honda mtf.
still havnt been able to get the screw off of the current purge cut solenoid. im hoping the replacement from the d16z6 will work. if that doesn't do it ill look into replacing the vapor canister.
also the outer axle boot on the passenger side recently split so that will be fun.
