Old 06-07-2013, 03:11 AM   #77 (permalink)
alvin_wj
Originally Posted by AndrzejM View Post
I had a similar issue with data not saved to EEPROM. But the problem disappeared one day on it's own. Can't say why.
Anyway i'm using Arduino Uno board with parallel LCD, without I2C interface.
I'll upload new code to my MPGuino and make some changes to it soon, because of some customizations. I'll share the code as soon as I'll test it.
That would be great! I've been trying to put the 0.82 with Arduino IDE 1.0.4, but it tells me that i don't have the wire library or something
Anyway, my MPGuino is connected directly to the battery. After 8 hours of idling, the LM 7805 is quite hot (like 35-43 deg C). Is it normal? I'm using heatsink for the LM. I'm measuring the heatsink temp.
Thanks
