Is it a manual?
-if so how dedicated are you? I ask because you could use a kill switch to EOC "engine off coast" make sure your steering wont lock up but it shouldnt if you dont turn the key off "try in parking lot first" and then bump start or use the starter to restart the car when you bump start FYI I use 5th gear all the way down to about 35 mph and then 4th down to 15 any less it feels rough to bump start but that will depend on the car
-grill block use scan gauge to measure engine temps
-electric fan
-remove power steering
-belly pan
-pizza pans as aero wheel covers
-smaller mirrors
-removal of roof rack if you have one
there is a list of 65+ aero mods on the top of the site
hope this helps! welcome to EM!
