Nice work, looks good. I really like that you have the option to use either the foot pedal or hand lever. I wonder if there is a way to do something similar, but allows you to lock the throttle position on the hand part. This way you wouldn't have to hold your hand there the whole time, you would just put it where you want and lock it. You would still be able to accelerate with your foor pedal and if you need to brake just unlock it and apply the brakes. I think this would be ideal for long highway trips.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
