Originally Posted by AndrzejM
Yes it can get hot, but even 50 degrees is not a problem.
If you have problem with IDE104 try to use the code changed by stargazerf3a
You'll find it here MPGuino metric v0.82 IDE 103
I didn't saw that
Thanks for the info
Now I'm trying the 0.82 now cause mine got a little problem.
After filling my tank, the MPGuino start to acting weird.
The character are going to ?*# something like that.
I know that i made a mistake when putting the power cause i didn't use a connector. The cable too thick, it's give me a trouble to put it in a 3-pin connector.
So, i'm going to fix it by putting a on/off switch for the -12V. So i can turn it on fast enough without damaging the EEPROM.
Hope this will be okay, cause i have to fill my tank again to calibrate it.
