[General comment: I used to frequent a board like this often enough that they made me a moderator. I saw people get aggravated at seeing the same question umpteen gazillion times. The ones getting aggravated tended to be frequent visitors themselves. I suggested that they spend the energy making FAQs rather than ranting at n00bs. We got some good FAQs.]
Originally Posted by SmellyCat
I replaced bigger cooler fatter stock tires on my Tacoma with some taller skinnier un cool road only tires. Got maybe 1-2mpg gain. It was not worth it because my truck looked stupid with street tires. Maybe if I got 5 mpg gain it would be worth the humiliation. sc
2MPG in a pickup truck is nothing to sneeze at, is it? I don't drive one, but I'd assume that 2MPG is probably somewhere around 10% improvement.
Originally Posted by mcrews
I use the Garmin GPS mph reading, but you could use the scangauge
I'm very interested in hearing how one might go about using a scangauge to correct for speedometer error brought on by changing tire diameter from stock.
