Old 06-09-2013, 10:20 PM   #4 (permalink)
pete c
Sounds like that damn engine computer is a little too smart for its own good. It looks at the various inputs, does the math and says something is screwy. This job sounds like it will require the ability to actually modify the computer's code. Maybe you can get away with smaller changes. Rather than the fixed resistor you added, you could try a variable. Start it at 0 Ohms and slowly increase it, a bit at a time.
Good luck with that! You'll need it.
